Fuel in oil
Old Sep 18, 2014 | 02:37 PM
fast69's Avatar
Default Fuel in oil
I just bought a 2001 lb7 duramax that ran fine but the injectors leaked real bad at idle I purchased kits and o/h my injectors runs great except gets fuel in oil did the vac test on the return lines and right side leaks about 1 lb for 30 secs. Should I remove injectors and have tested for split or just try to seal up line or gaskets I would get a gallon or two in 300 to 400 miles. Some say to replace the lines Is that needed don't really want to pull apart again I still like this truck and don't want to HATE IT!!!
Old Sep 22, 2014 | 07:26 PM
Walker.B's Avatar
sounds like cracked injector body's which means you need a set of injectors most likely
Old Sep 22, 2014 | 08:09 PM
4x4manonbroke's Avatar
High pressure lines , or cracked injector(s) ..
Old Sep 23, 2014 | 07:52 AM
fast69's Avatar
Thanks Guy's, I have the right side opened up and I am going to pull those four injectors and have them checked. (not an easy fix out here in the boonies)
Old Sep 23, 2014 | 04:33 PM
Or in a shop that has every tool ..
Old Sep 24, 2014 | 05:21 PM
2500HeavyDuty's Avatar
i never try to re use gaskets under the valve covers. but yeah its a real pain working with those.
Old Sep 25, 2014 | 08:51 AM
fast69's Avatar
I just took my rebuilt injectors to des moines and had the right side injectors tested 3 of them leaked from the bottom nut the instructions said to put rtv on thread which I did did I miss something when I put new nozzles in the injectors?? Thanks Guys for all the feedback
Old Sep 25, 2014 | 12:04 PM
Walker.B's Avatar
still sounds like cracked injector bodies to me which cannot be repaired. only way to fix cracked bodies is new injectors
Old Sep 25, 2014 | 12:20 PM
rtv on what?
Old Sep 26, 2014 | 01:29 PM
fast69's Avatar
Default rtv
I was told to put rtv on threads of upper and lower caps of the injector
