Smoking problem.
Old Sep 17, 2014 | 09:26 AM
Texas Diesel's Avatar
Question Smoking problem.
I have a 96 2500 auto, with a bhaf 4in exhaust and the stock fuel plate slid forward. when I give it full throttle it smokes a little bit, but every now and then it will just black out the highway. it only does it like 1 out of 50 times. any idea what may be causing it?
Old Sep 17, 2014 | 09:38 PM
4x4manonbroke's Avatar
Please fill out the sig ...
I would assume that your trans is starting you off in 2nd gear ... that will do it ..
try shifting to 1st, then take off and shift up manually .. make sure the trans is warm .. I shift mine both up, and down ..
Keep posted on what it does ..
Old Sep 18, 2014 | 09:34 AM
How do you fill out the sig?
Old Sep 18, 2014 | 04:14 PM
go to your personal info ... there will be a place to fill out signature (sig).
Old Sep 18, 2014 | 06:29 PM
I tried what you said and it smoked lightly like normal.
Old Sep 18, 2014 | 07:11 PM
I am gonna say your having a low fuel pressure @ IP from Lift pump .. Need to get a gauge on it and find out what it is ..
What is you IP timing , Run me through your mods ..
Old Sep 18, 2014 | 07:57 PM
The stock fuel plate slid forward, Bhaf, and 4in exhaust. Also a factory rebuilt transmission.
Old Sep 19, 2014 | 10:59 PM
I would say fuel pressure ...
Old Sep 20, 2014 | 09:57 AM
Lift pump just started ticking that's the problem!
Old Sep 20, 2014 | 11:42 PM
Yeah .. that will cause some issue .. Need to put a gauge in it to ensure your not tossing parts just to toss parts ..
