Wheel compatability
Old Sep 16, 2014 | 10:52 PM
tREEDx's Avatar
Default Wheel compatability
looking to buy some tires. i found a used set off a 2010 ram 2500 that have the stock wheels on them. i have wanted to find a set of stock wheels as i like the look of them, and my wheels are peeling. my question is can a wheel off a 2010 ram 2500 be installed onto a 2004 ram 2500?
Thanks in advance
Travis
Old Sep 17, 2014 | 04:00 PM
Just-Another-Dieselguy's Avatar
yes
Old Sep 17, 2014 | 06:49 PM
tREEDx's Avatar
OK thank you!
Old Sep 20, 2014 | 12:42 AM
tREEDx's Avatar
so i bought the tires and wheels. they came with center caps and lug nuts from the 2010. my old lugnuts are like 3" long use keys to get off. but the stock center caps wont work with
these so i have to use the nuts from the 2010 that the wheels came off of.Today i tried to change them and after getting one corner off i put the wheel on. it was a very close fit but it seemed to go. however when i went to put the lug nuts on they threaded on a few threads then stopped. the old and new nuts threads looked the same so i tried again and after a thread or two it stopped. so i used a ratchet with light pressure and it started to move again after 3 or 4 more threads it started to get tighter and tighter. i backed it off and neither of the threads looked obviously damaged. so i kept tightening it. it finally seated and squeeked the last few turns. all 8 went on like that. it required a standard ratchet and alot of muscle, but i never had to use a breaker bar, i only have installed one wheel lest i screwed up something. any thoughts? the pitch on both styles of lug nuts seems the same but it has a definate interference fit. which is harder the wheel stud or the lug nut. i would imagine the wheel stud since its much easier to replace a nut than the stud. but maybe not. so i need to know whether to continue or to stop and replace the 8 wheel studs and move in a different direction. thanks in advance.
Travis
Old Sep 23, 2014 | 03:09 PM
you may just need to get stock lug nuts for your truck. I phoned a friend just now and he said "they have been the same forever, 8x165mm"
Old Sep 30, 2014 | 08:34 PM
tREEDx's Avatar
Thanks, the lug nuts that weren't going on were the stock ones. but I think the problem is/was just built up rust and corrosion on the wheel studs. I was replacing the unit bearing at the same time and the lug nuts fit wonderfully on the new studs of the unit bearing.
thanks again
Travis
Old Sep 30, 2014 | 09:51 PM
Glad it worked out for you man! If like to see some pictures when you get time! Have not seen that wheel on that truck yet..
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
