2011 2500 delete help
Old Sep 15, 2014 | 06:38 PM
Capt. Tim's Avatar
Default 2011 2500 delete help
Hi new here and looking to do the deletes on my truck. Im not looking to make alot of hp just want to let the motor breath. Want to do full exhaust. What are some good options? I want to delete the throttle control valve also thanks
Old Oct 1, 2014 | 06:06 PM
perk7089's Avatar
Hi I got a 2010 6.7 and I'm a believer in H&S mini maxx,h&s intake horn, h&s boost pipe, s&b intake,5" flo-pro all the way... Love mine!!!
Old Oct 17, 2014 | 09:55 PM
5.9Cumminsturbodiesel's Avatar
same here getting 2011 ram 2500 6.7L would like to the EGR, DPF deletes, head studs, programmer but what deletes void warr. on the truck ?
Old Oct 18, 2014 | 05:16 AM
perk7089's Avatar
Any and all deletes to the emissions... Adding a programmer, which u need to delete the emissions BS!!! I would never done it any other way!!! No regrets throwing my warranty away!
Old Oct 18, 2014 | 07:54 PM
thanks good to know
Old Oct 19, 2014 | 07:50 PM
jimmysinejr's Avatar
Deleteing my 6.7. How much added power can i give it without doin head studs
G
Old Oct 19, 2014 | 08:08 PM
perk7089's Avatar
G
Just from what I've read it seems these blow gaskets easy so you should just do it to be safe but I heard up to 40psi boost should be safe... Mine puts out 36psi boost n didn't get them yet... The only thing I've blew out is my 5th & 6th gears so far... And I run the ***** off mine.... If ur gna run it I suggest getting ur tranny built asap! BC the power difference is incredible! The stock tranny can't handle it.... Good luck!
Old Oct 22, 2014 | 06:47 PM
hope to do the Dpf ,egr, headstuds, mini maxx progammer, maybe s&b intake and your saying to do built tranny on it ? didn't think doing these delete's would change that much and don't plan on beating the snot out it proabaly be on stock or mild tune most of time maybe wild if towing
Old Oct 22, 2014 | 06:50 PM
perk7089's Avatar
Ul be AMAZED at the difference it makes!!!! I was blown away!!! I leave mine on performance all the time... It has a tow setting on it too.... But I'm sure if u think it won't make much of a difference ur in for a HELL of a surprise bro!!!... I promise!!!
Old Oct 22, 2014 | 06:55 PM
perk7089's Avatar
And the tranny build is necessary BC it can't take the power ur about to put out!... I tore 5th n 6th out after launching n racing it a couple dozen times...n I got everything ur about to do except head studs on my 2010 2500 crew cab 8' bed 4wd... N its insane!... Mini max estimates 1071 ft/lbs torque & 13.2 sec. 1/4 mi...
