Bad miss at 1500-2000 rpm??
Old Sep 15, 2014 | 04:14 PM
Json4au's Avatar
Default Bad miss at 1500-2000 rpm??
Ok guys I had new injectors from river city put in my 07 f250 and also a new power max and also a fass fuel pump,well now it is bucking and missing real bad has anybody had this problem??
Old Sep 15, 2014 | 04:43 PM
Adrenaline junkie's Avatar
Need more info. Was it running good after new parts, then problems or has it been since work was completed?
Old Sep 15, 2014 | 04:49 PM
Json4au's Avatar
Running fine before the install and then new install it started missing. It also has egr delete that has been done and head studs
Old Sep 15, 2014 | 04:50 PM
Json4au's Avatar
It has 155cc injectors
Old Sep 15, 2014 | 06:13 PM
bobfbigman's Avatar
check all your connections on the injectors, pull on connectors a little to make sure they are tight. Also check the connections on the FICM, that miss is an injector not firing
Old Sep 15, 2014 | 06:51 PM
Json4au's Avatar
Thanks man I will try that.
Zach56238
Sep 3, 2015 06:57 AM
Hmfman91
8
Jul 3, 2015 05:52 PM
southeren_born
Mar 28, 2015 09:19 AM
BYRQN33
Mar 18, 2015 04:12 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
