Rear end swap speedometer gear?
Old Sep 14, 2014 | 07:20 PM
Waj12v's Avatar
Default Rear end swap speedometer gear?
Gonna swap out my open 3.54 rear with a 4.11 gear posi rear axle. I can't find anyone that sells any speedometer gears for it. I don't know if there's a way you recalibrate it or what you have to do to get the correct mph reading after I swap it.
Any info would be greatly appreciated.
Old Sep 14, 2014 | 08:26 PM
turbo2332's Avatar
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
i think you will need a 35 tooth. if i recall right thats what i used when i went from 3.54's to 4.10's and 33 inch tires.
hope that helps
Old Sep 14, 2014 | 08:30 PM
six speed's Avatar
the speed odometer gets its reading out of the transmission. you can get the correct part at the dealership and probably at most any parts stores.
Old Sep 14, 2014 | 09:01 PM
turbo2332's Avatar
not if it is a 4x4 it comes out of the transfer case.
Old Sep 15, 2014 | 12:21 AM
4x4manonbroke's Avatar
I went from 3.55's from 4.10's .. and yeah . Its way the Heck off !!!!
Old Sep 17, 2014 | 09:53 PM
six speed's Avatar
yes sir you are right. i had done it on a 2wd and forgot to put in there that the 4wd came out of the transfer case.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
jonnyb2crazy
Mar 26, 2015 10:23 PM
perk7089
Oct 11, 2014 05:03 PM
