04 6.0 Rough idle/White smoke
Old Sep 13, 2014 | 04:18 PM
emilio2496's Avatar
Default 04 6.0 Rough idle/White smoke
Hello! I have a 2004 F250 6.0. Just did an egr delete a couple weeks ago, truck was running great. All of a sudden went out to start it and took a little bit to crank. Truck started idling rough,sounded liking a knocking almost. It only does white smoke when accelerating. Plugged in a scan tool came up with code p0284/ Cylinder 8 Contribution/Balance Fault. Thought it was the injector so i replaced the #8.The old injector had normal ware on it. Started it and still ran the same exact way. Finally took it to a mechanic and they said i have no compression in Cylinder #8 at all. Telling me iam gonna need a new engine . I really need some help guys i have no idea what to do
Old Sep 14, 2014 | 06:19 AM
Adrenaline junkie's Avatar
Did you make sure you put injector in correctly, with o rings and sealing copper ring on bottom?
Old Sep 14, 2014 | 12:23 PM
emilio2496's Avatar
New injector already came with new o rings and copper ring pre installed.
bdbfam
Aug 31, 2015 09:06 PM
desperatemofo
Aug 4, 2015 12:25 PM
jordanokc
Feb 8, 2015 03:59 PM
Fishy816
Jan 11, 2015 08:31 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
