P2509 P0069 P0192
Old Sep 13, 2014 | 12:04 PM
dodge*this's Avatar
Default P2509 P0069 P0192
Any idea how to take care of these issues? I put new fuel filter on after getting codes and it starts and runs very rough. Rattles big time. Before I put the filter on I could hardly get it running.
Old Sep 14, 2014 | 11:32 AM
FlyingDutcman's Avatar
p2509 (powerdowndata lost error) check your connections
p0069 (MAP - barometric pressure correlation) check your air filter and IAT sensor, something is confusing/messing with your MAP sensor!
p0192 (Fuel rail pressure sensor) voltage too low
All sounds like it can be fixed spending some time cleaning/checking connections and ground! These trucks are definitely sensitive too it! good luck!
Old Sep 14, 2014 | 08:57 PM
dodge*this's Avatar
Is it possible the battery amps are low? The battery voltage is fine. I have cleaned battery terminals and grounds. They are original batteries in an 06. I did unplug my quadzilla xzillaraider and it ran like a champ so I took it off. Drove it today and codes still showing. I am hoping the codes go away after a few drives.
