01cummins. ac issues
Old Sep 9, 2014 | 09:23 PM
coors_man_2005's Avatar
Default 01cummins. ac issues
My dads truck ac works great for about 15mins then turns hot. Shut it off for 10. Works for another 15mins. Its like its freezing up. But. What would cause it thanks a lot guys
Old Sep 10, 2014 | 04:15 AM
gh0stman's Avatar
Have you checked the freon levels? I had the same issue at the house for the AC turned out the ever so wonderful family members I had put in the unit and charged by the pound for freon put to much pressure and had to bleed it off. If its not the freon levels I would check compressor.
Old Sep 10, 2014 | 06:02 AM
We have been debating changing the pump. We changed a line cause someone had told us there was an orphase that could be plugged. And it does the same as before. The freon is correct level.
Old Sep 10, 2014 | 10:36 AM
GreenDieselF's Avatar
Your evaporator could be icing up due to insufficient air flow... Just a thought
Old Sep 10, 2014 | 01:25 PM
Would you be able to see the ice on the evap
Old Sep 10, 2014 | 01:27 PM
gh0stman's Avatar
It would be under the dash I believe. Could have some trash blocking it.
Old Sep 10, 2014 | 01:31 PM
No the evaporator is in front of the heater core enclosed in a plastic housing. Normally if it ices up you'll notice less airflow through the vents and warm air. You could check the evap. housing drain it's in the engine compartment on the passenger side down on the fire wall. Also running the fan on high and the temp a little higher and see if that helps
Old Sep 10, 2014 | 07:01 PM
Ok thanks guys I will get with my dad this wkd and see if we can straightin this out. Thanks
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
Apr 11, 2015 02:47 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
