will my trans hold??
Old Sep 7, 2014 | 04:56 PM
bajahigh's Avatar
Default will my trans hold??
ok so im getting 190cc injectors and im just wondering if my truans will hold to all that power my friend was running the same set uop except with a edge chip n his trans only lasted a month should i get just a streetv tune??
i have a 04 with sct getting quick tricks tuning have head studs updated oil cooler egr delete cold air intake 4in exhaust S&B cnc pipe coolant filter BD boost builder and a 58v ficm
Old Sep 7, 2014 | 07:15 PM
HeavyAssault's Avatar
190's on a stock turbo isn't going to work well. Your buddy toasted his trans due to using the Edge unit.
Old Sep 8, 2014 | 02:05 PM
bajahigh's Avatar
I'm doing a wicked wheel II while I do injectors and whys the edge so bad for 6.0?? The shift on the fly bad for it?? Will my trans hold with 190s and a wicked wheel?? As long as I have good tuning?? Or should I go with a street tune?? Also wanting. Fuel pressure and egr gauge does the sct have a adapter cable for fuel psi I know they have the analog able thing wat all gauges does that add??
Old Sep 8, 2014 | 03:21 PM
gunman41mag's Avatar
Moderator
If you're near 500 HP your factory stock 5R110 is taking a beating, it's life will be shorten
Old Sep 8, 2014 | 08:54 PM
Adrenaline junkie's Avatar
Innovative SCT tunes changes trans settings and makes it all work together.
Old Sep 8, 2014 | 10:16 PM
bajahigh's Avatar
im also doing the blue spring and banjo bolts when im doing injectors and getting the sct egt probe but what all does the sct firewire/ analog cable add to the gauges???
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
Walker.B
LB7 Performance
Jun 29, 2015 09:38 PM
pv89sj
Oct 12, 2014 02:45 PM
Pyrohigh
Oct 11, 2014 07:59 AM
