DRW LB to SRW SB (2wd)
Old Sep 6, 2014 | 06:53 PM
jdepuy618's Avatar
Default DRW LB to SRW SB (2wd)
I want to do a DRW LB to SRW SB conversion on my 2000 ram 3500. I know the rear dana 80 is a bit wider but besides that my question is can I cut the back of the frame behind the spring mounts and drop a diesel short bed right on, or will I have to slide the axle and spring mounts forward and shorten the driveline etc.?
Old Sep 8, 2014 | 05:10 AM
gh0stman's Avatar
Doing such a conversion would take a lot of work. you would have to probably cut and reweld the rear suspension, have to get a new shorter drive shaft, cut the excess frame, cut the old bed mounts and reweld them as well. I was reading the other day a guy that went from DRW to SRW the the dana 80 will stick out about 2 inches on either side. But he kept the same bed length. So I would do one of the 2 leave it as a long bed or sell it and buy a short bed.
remier8816
Apr 19, 2015 10:33 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
Gman30
Dec 27, 2014 12:46 PM
Machinist
Dec 5, 2014 01:06 AM
ryanf
Oct 13, 2014 10:14 AM
