97 3500 no crank
Old Sep 4, 2014 | 11:13 AM
Farmallmilitary's Avatar
Default 97 3500 no crank
Yesterday I went out to my truck and went to start it and the starter isn't doing anything. I checked and I am not getting any power on the signal wire at the starter when I turn the key. I can jump the signal wire and it cranks so I know the starter isn't bad. Next I checked the relay and used a good one I had sitting around but I had no luck. I am also not getting any power to the pull wire on the fuel solenoid. At the power distribution box on the relay i get 2 prongs that are keyed power and one that is starter power. The one that is starter power is suppossed to be a ground from what I can tell on wiring diagrams. So this is probably my problem but I can't figure why it is doing this. I am lost, it was working just fine yesterday. I would appreciate any ideas.
Old Sep 4, 2014 | 11:23 AM
4x4manonbroke's Avatar
trigger wire came undone @ starter ?
Starter relay ?
Old Sep 4, 2014 | 11:37 AM
Starter relay is good I have a good extra one and put that in and didn't change a thing.
Wire is good down to the starter and connected well.
I am stumped I don't understand it was working just fine when I parked it but overnight it decided to stop working.
Old Sep 4, 2014 | 11:43 AM
Start checking fuses.. use an indicator .. or use an ohm meter with the fuse removed .. I find more issues with fuses that anything .. they can come unsoldiered and still look ok....
Old Sep 4, 2014 | 08:23 PM
I couldn't find a fuse for the starter. Where would that be located? All I found was the relay but no fuse.
Old Sep 5, 2014 | 09:21 PM
I was thinking maybe see if the trigger wire is getting the signal .. if not your gonna need a Wiring Diagram and your gonna need to trace it down ..
Old Sep 8, 2014 | 09:27 PM
coors_man_2005's Avatar
There is a fuse it got me on my conversion. It's in the panel under the hood
Old Sep 8, 2014 | 10:44 PM
Well I looked everywhere for the problem and could not find it. In order to save time and headaches I just installed a push button for the starter/ fuel solenoid and put it in a semi-hidden area. This gives the truck a little added security. It is just a simple fix but if it works then I have no problem with it.
Old Sep 12, 2014 | 11:44 PM
That works . for now ..
ish1521
Aug 26, 2015 08:42 PM
Jun 22, 2015 12:40 PM
Mr. Walkway
May 11, 2015 10:49 AM
Polaris04
Dec 1, 2014 08:27 AM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
