12v p pump issues
Old Aug 30, 2014 | 11:15 PM
Alfred Bruce Millett's Avatar
Default 12v p pump issues
hey guys so i had a problem with my 12v the mech lift pump was leaking diesel into my oil so i plated it off it has a aftermarket lift pump on it after that it cranked and drove fine for lile 8 miles or so then i shut it down and an hr later cranked it up started driving and everything was normal i got on it a little and the truck started to cut out then the pump made a wierd noise and started to fuel with no control all threw the rpms til gov spring hit. what causes this poor lift pump pressure or p pump going out ? it would fuel for about 10 secs then let out when it would do this any help please!!!
Old Aug 31, 2014 | 06:54 AM
94 12valve's Avatar
did you check your fuel pressure after the lift pump install? and did the injector pump make this weird noise or the lift pump?
HardLuck
Jun 24, 2015 08:04 AM
ItsAChummins
May 15, 2015 05:02 PM
moneypitk5
Feb 12, 2015 11:01 AM
StreetRat
8
Jan 15, 2015 03:45 PM
letters4and18
Dec 11, 2014 12:03 PM
