Need help again !!
Old Aug 27, 2014 | 05:14 PM
Brokencummins's Avatar
Default Need help again !!
Ok so ever time I open the gas cap it will run for like 5 mins then shut off and won't start. The lift pump is still primed but I crack the injector and no fuel. Someone please help
Old Aug 27, 2014 | 05:49 PM
turbo2332's Avatar
your probably sucking in air somewhere pre lift pump
Old Aug 27, 2014 | 07:33 PM
Where should I start. I cracked the line coming off the fuel filter and only alittle came out
Old Aug 27, 2014 | 09:31 PM
I cleaned the filter on the sending unit it was bad do you thing it's a filter problem or a pump problem
Old Aug 28, 2014 | 03:11 PM
4x4manonbroke's Avatar
have you deleted the Heater .. Mine leaked there , I did the delete and never have had an issue since ..
