Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
Help with Woods Diesel Commercial Mower
Old May 4, 2008 | 09:59 AM
psemerak's Avatar
Default Help with Woods Diesel Commercial Mower
Hi all
Well I have a woods diesel 5215 three Cylinder.
Last summer I had a problem and it turned out to need a new starter.
New starter is on - she cranks but seems to not be cranking fast enough to
fire it.
- I fully charged the battery - I bled the lines - even plugged in the block
heater.
But still when it cranks, she won't fire
Little puffs of smoke come out like she wants to, but she won't light.
Unfortunately its a hydrostatic so I can't to it to fire...
I'm preheating for a good long time as well
Any ideas?
Thanks!
Pete
Old May 4, 2008 | 10:07 AM
Buckshotmckee's Avatar
Sma't Alec!
It sounds like your pre-heating system is not working. Getcha a test light and see if your getting power to it. If you are, then the heater is probably bad.
Old May 4, 2008 | 10:08 AM
00' Quad Cab's Avatar
Give it a little shot of starting fluid or WD-40 yet?
Sometime they can be a pain but once you get them running they are fine.
Old May 4, 2008 | 10:22 AM
Sma't Alec!
Forgot about the WD-40 trick. Something that works better then WD, getcha a old towel/rag and put some gas on it, hold it over the intake and start it. Make sure you have a good grip on the rag so is doesn't get sucked in.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
