Huge oil leak top of motor 6.0
Old Aug 22, 2014 | 11:41 PM
Bropeen's Avatar
Default Huge oil leak top of motor 6.0
After replacing the oil cooler I had a coolant leak from oring on bottom of intake. After fixing that the motor developed a big oil leak somewhere on the top of the motor. Oil pools up by the turbo return pipe and runs down the valley to the bell housing, etc. The leak only presented itself after I replaced the oring on the bottom of the intake to the egr cooler. I only removed the bolts from the intake and lifted it to replace the oring. What could I have messed up? The leak is extremely big. Losing about 5 quarts of oil in 100 miles.
Old Aug 23, 2014 | 07:45 AM
HeavyAssault's Avatar
Did you check the oil drain tube off the turbo?
Old Aug 23, 2014 | 12:59 PM
Bropeen's Avatar
Yes. It immediately pools around the small housing that connects to the egr cooler with the two inch hose. Could oil leak from there ? I thought coolant flowed there.
Old Aug 24, 2014 | 10:36 AM
How about the oil feed line? There is a small o-ring on the bottom.
cummins Pride
Sep 28, 2015 12:11 PM
Sootboyz89
Jun 28, 2015 02:31 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
