Front Driveshaft U-Joints?
Old Aug 22, 2014 | 09:21 AM
mt_wi86's Avatar
Default Front Driveshaft U-Joints?
Good morning!
Having some trouble figuring out which u-joints i need for my double cardan joint on the front driveshaft. I have the spicer 5-795x picked out for the diff end, but cannot figure out which I need for the double cardan. Apparently there are two different sizes? Can someone please shed some light on this for me? I have been google searching etc for a couple hours and my head is spinning with part numbers.
BTW 2004 Ram 3500 SRW H.O. CTD 4x4 Auto
I am rebuilding sloppy front end, so far have the following in my cart
Dynatrac BJs
Spicer 5006813 for axle shafts
SKF wheel hubs (oe manufacturer I'm told)
Yukon Pinion seal & nut
CV ball kit for front driveshaft
Spicer 5-795x
Also OTC 8031 bj press
and already have the T-link steering update sitting in the garage with new stabilizer, pitman arm, and nuts.
Anything I am forgetting before I order parts?
TIA
Old Sep 16, 2014 | 01:02 PM
Spikes's Avatar
Hi, First post here.
The Cardan joints on your front shaft are 2-4800 (Neapco), 5-213X (Spicer greaseable) or 5-790X (Spicer no maintenance) 1330 u-joints.
Edit-- I just saw where even Neapco says there are two different u-joints used on that year. The numbers above are for the 1.063" cap, the larger joint is below.
1350 series with the 1.188 cap are 2-0052 (Neapco), 5-178X (Spicer greaseable), 5-799X (Spicer no maintenance).
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
