Max Mileage Boost fooler question??
Old May 3, 2008 | 07:44 PM
dieselgrl4life's Avatar
Cowgirl with a Cummins
Default Max Mileage Boost fooler question??
Will this downloadable update to the max mileage create to much psi for my truck to be able to handle? Is it the same as putting the actual quad boost fooler on ur truck ? or does it just allow boost to build faster?
Old May 6, 2008 | 08:16 AM
Meyer Performance's Avatar
No you will be fine they dont make it so it overboost truck
Old May 6, 2008 | 08:48 AM
staarma's Avatar
Yep, you'll be fine. It will allow you to build a little more boost sooner. Ultimately you need more fuel to build boost. You really don't have any fuel adders......yet so no need to worry. Your truck will safely build boost to ~48 PSI, before you would need to worry about a headgasket, and more boost with a better matched turbo that would be more efficient with better drive ratios than the stocker.
Old Jun 24, 2008 | 02:32 AM
emp1134's Avatar
I would run the boost fooler it will help lower your egt's abunch. like Staarma said your safe below about 48psi.
Old Jun 24, 2008 | 07:13 AM
GRI's Avatar
GRI
My understanding is that the boost folling tune for the M3 wont do anything for mileage or power as the box is set up to increase mileage and if you need to boost fool you'll be out of the range of the area that the module works in.
|WYG|SS
Jul 26, 2015 11:18 AM
RexShoppe
Price Quote - Request A Price
Jun 16, 2015 02:48 PM
Crews8r
Dec 21, 2014 07:35 AM
somarillw
Dec 4, 2014 12:37 AM
scottxmorris
Nov 11, 2014 03:28 PM
