rusty turbo bolts
Old Aug 19, 2014 | 06:50 PM
Shawnk24v's Avatar
Default rusty turbo bolts
I want to replace my downpipe to install my new exhaust but I noticed the turbo flange bolts were a little rusty. Was wondering if I could get any help on proper ways to remove them without possibly breaking tthem Any help is greatly appreciated!!
Old Aug 20, 2014 | 04:31 AM
gh0stman's Avatar
PB Blaster, WD40. Rust penitrant something that will get in and loosen the stuff up.
Old Aug 21, 2014 | 10:14 PM
Anh Chà n's Avatar
Use a welding torch to heat the bolts up if you got one .. That will be lot easer
Old Aug 22, 2014 | 04:12 AM
gh0stman's Avatar
I was reading around yesteday and saw where a guy had used a 50/50 mix of ATF and Acetone. Supposedly it works miracles but greatly reducing the amount of force you have to put on the bolt. IIRC they said that to get a rusted bolt with no penetrant took about 500 ft-lbs to loosen, while the ATF/Acetone took only 50-60 ft-lbs of force. Worth a shot with some heat and this mixture.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
