FASS pump to replace mechanical LP.
Old Aug 16, 2014 | 05:27 AM
GreenDieselF's Avatar
Default FASS pump to replace mechanical LP.
I have a 2000 dodge 2500 with a 5 speed and I just ordered a S&B cold air intake as well as a intake manifold. My next purchase is goin to be a fass fuel pump to replace the stock mechanical lift pump. My few questions are when I install this fuel system will I need to order a plate to cover the stock lift pump mounting location or does the fass system still utilize the mechanical pump? Also does it come with all lines etc to install? What about a "draw straw" I've been reading about? I plan on putting the larger titanium series pump on. In the very near future I want to add an edge comp box or EJWA, larger injectors and head studs.
Old Aug 17, 2014 | 11:26 AM
yjay's Avatar
Head studs wouldn't be necessary with those mods in my opinion. Unless you did pretty big injectors. I'd reuse the stock bolts if they are in spec for stretch. A draw straw won't be necessary either. Others may disagree. I have a Raptor 150 and it supplies 18 psi at idle and 12 to 13 at WOT with the Juice on 5. Fass is a better option I've heard but mine works fine so far.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
ramrunner01
9
Jun 4, 2015 03:34 AM
MREILLY
Apr 8, 2015 01:27 PM
moneypitk5
Feb 12, 2015 11:01 AM
