'03 5.9 Shuts Off, New Injectors
Old Aug 15, 2014 | 02:56 PM
Farlander's Avatar
Default '03 5.9 Shuts Off, New Injectors
I work at a shop and we have had this poor ladies truck for over 2 weeks. She came in complaining that the truck would run normally but would not restart when hot. The dealer recommended all new injectors, we suspected injectors had excessive leak back, so we replaced all six. After replacing injectors (without any special tools) the truck now shuts off by itself after a few minutes. It will always restart no problem. The high pressure fuel reading starts at about 4800, and then slowly drops over a few minutes until about 2700 psi and then the engine dies. Unplugging the FCA makes doesn't seem to make a difference. The flow test from the low pressure pump seems shows low fuel flow, but the pressure from the low side is about 15 psi. Any thoughts? New filter in the separator bowl, but not sure if there's a frame filter or not.
Thanks in advance.
Joe
Old Aug 16, 2014 | 11:18 AM
Farlander's Avatar
Solved the issue, the high pressure lines from the rail to the head were not tight enough at the head. Torque spec is 44 FOOT POUNDS on those fittings. They were snug but not torqued down. After using a crows foot and a torque wrench, the truck is holding fuel pressure at idle of 5300 psi!!!
CHAMP31707
For Sale
Jun 1, 2015 04:03 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
cumminsaddict199
Dec 22, 2014 09:57 PM
