fca maybe
Old Aug 12, 2014 | 07:14 PM
cummins2132's Avatar
Default fca maybe
OK I replaced the dual cp3 controller because it was blowing fuses and had a high rail pressure idle. When I replaced the controller it stopped blowing fuses but still has the high rail pressure what causes it fca or bad rail pressure sensor or what.
Old Aug 12, 2014 | 07:20 PM
AHolt's Avatar
I am thinking bad rail sensor.
If you have anyone near you that has a truck with cp3, ask them to swap out to test
then you will know.
Old Aug 12, 2014 | 11:04 PM
a bad rail sensor can cause it to have that rough idle rite or no
Old Aug 13, 2014 | 06:39 PM
at idle its rail pressure is at 25k to 26k could it still be a bad rail sensor
Old Aug 13, 2014 | 07:23 PM
AHolt's Avatar
The only problem I had was with fca.
The truck would stop running, let it set for a minute, would run again.
I changed it, no more problem. If you lived closer I would let you try one
of each and see if that is the problem. That is why i said try and find someone
close to you and swap them out, would take a couple minutes to see if that is
your problem. Have you checked for codes. turn key on and off three times.
Old Aug 13, 2014 | 07:29 PM
the guy replaced with 2 new fca's still no change it dropped maybe 1000 psi. im cornered its in abilene tx i cant find anyone thats willing to swap parts to let me test. we do know the rail is leaking from where the pressure relief valve is
Old Aug 13, 2014 | 07:49 PM
AHolt's Avatar
If the rail is leaking, that is part of your problem.
I have a new rail, and some used sensors here.
I will sell you the rail and sensor for $100 plus shipping.
Old Aug 13, 2014 | 09:07 PM
The sensors and rail still good and where you located bc I wanna do next day air if possible
Old Aug 13, 2014 | 09:38 PM
sorry sensors they still good
Aug 6, 2015 02:30 PM
Jul 30, 2015 08:00 PM
Jul 24, 2015 10:30 AM
May 17, 2015 12:10 PM
lineman71
Nov 24, 2014 02:07 PM
