Mods for under a Grand
Old Aug 12, 2014 | 01:20 PM
AspenR's Avatar
Default Mods for under a Grand
Just bought my first cummins, and I'm wonder what good performance mods I can do for under a $1000. Truck already has a fass lift pump, and a new stock replacement clutch. What can I do without changing internals, and with the original type clutch?
Old Aug 12, 2014 | 02:21 PM
rreed79's Avatar
Gauges!
Old Aug 12, 2014 | 07:35 PM
AHolt's Avatar
What he said, gauges first so you can monitor what you
already have.
Old Aug 12, 2014 | 07:46 PM
AspenR's Avatar
That was my first thing I was planning to do along with cutting out the muffler and putting in a straight pipe. I've been looking at tuners and chips and I'm wondering what would be the best for me, I daily drive the truck so I want to maintain the same fuel mileage if not better. What is some good mods to get me started in the right direction?
Old Aug 13, 2014 | 11:00 AM
Allen@XDP's Avatar
Supporting Vendor
Edge insight with expandable egt probe, smarty jr, remove the factory muffler. You should be happy with the power from it and you can monitor everything that way.
Old Aug 14, 2014 | 12:55 PM
Bigg Redd's Avatar
Forget the straight pipe. Yes, ditch the muffler, and get an Aero Turbine muffler, the 4040XL specifically. Sounds like stock, but barks a bit when you "get on it." I definately felt an increase in torque when I installed mine. Also helps decrease EGTs. I bought mine just to try it. Figured I would sell it if I didnt like it. Well, I love it and its staying.
Old Aug 14, 2014 | 01:07 PM
Bigg Redd's Avatar
Oh yeah, the current stock intake manifold will likely have 2 indents where 2 of the mounting bolts are located. That area literally chokes the pressurized intake charge. Going with a good free flowing aftermarket intake manifold, or even a stock 2nd generation cummins intake will boost your HP and TQ as well as decrease EGTs. 2nd gen intakes are relatively inexpensive, alot less than after market intake manifold(s). Also a free flowing air filtration system, CAI or the like will help your engine breathe easier.
Old Aug 14, 2014 | 01:15 PM
AspenR's Avatar
I didn't know you could run two tuners at once, how would you hook that up? Doesn't both hook into obdII?
Old Aug 14, 2014 | 01:22 PM
rreed79's Avatar
Yea I don't think it would work with a splitter. I guess you could load it up with the smarty programmer and then remove the smarty and plug in the insight to monitor your vitals? No on the fly changes I would assume.
Old Aug 14, 2014 | 01:28 PM
AspenR's Avatar
Do you know how tq the smarty adds, because on their website it just shows hp?
