buying an 06 powerstroke, what to look for?
Old Aug 11, 2014 | 09:27 PM
Dieselinmyveins's Avatar
Default buying an 06 powerstroke, what to look for?
hey guys i found an 06 f250 powerstroke with 268,000kms (not miles) that i want to go look at. it apparently has an egr delete and new head gaskets with arp studs. i'm just wondering if i go look at it what problems should i look for and how can i tell if it really does have arp studs done?
Old Aug 12, 2014 | 07:30 AM
03grey6.0's Avatar
one thing to consider when buying something with higher mileage is the suspension. check for any signs of leaking from the shocks, sway bar bushings, end link bishings, drag link, etc. also check your brake lines, fuel lines and tranny lines for signs of corrosion, split connectors, etc. make sure you get a chance to start it when then engine is cold. you should be able to notice any misfires, low ficm, etc. good luck!
Tylerbuckley
9
Sep 21, 2015 08:24 PM
4doorIDIot
6.9L & 7.3L Performance
Aug 1, 2015 06:02 PM
Lsugod85
Jun 20, 2015 05:14 PM
duramaxtuner
Dec 10, 2014 01:24 PM
11Bravo
Nov 16, 2014 11:23 PM
