2007 Ram 2500 oil burn??
Old Aug 9, 2014 | 12:09 PM
frogjaw's Avatar
ATTN 2007 Ram 2500 oil burn??
I had the engine rebuilt about 10,000 miles ago. It is blowing grey smoke and using a lot of oil. I held a rag over the exhaust and I got oil specks all over the rag, any ideas what could cause this??
Old Aug 10, 2014 | 08:54 AM
AHolt's Avatar
You will need to pull injectors, put bore scope in each cyl, check
to see if you have a broken ring. If their ok, could be main bearings.
I know you said new rebuild, but it happens.
Old Aug 10, 2014 | 07:30 PM
dangerous1965's Avatar
Rings or valve seals pick one! Stock cam?
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
