2004.5 rebuild - No Oil Pressure
Old Aug 7, 2014 | 08:17 AM
harleygreg's Avatar
Default 2004.5 rebuild - No Oil Pressure
Folks, I really appreciate your input and advice! Here's where I am after a complete rebuild of my 2004.5 5.9:
Issue - little or no oil pressure 12psi @1200rpm) on my rebuilt 2004.5 Cummins 5.9
What I've done to date (after rebuild):
1. replaced oil pump, suction tube, oil cooler & gaskets
2. verified that I have oil flow (removed filter and oil flowed into bucket)
3. checked oil and it is getting darker so it is circulating but little to no pressure
This weekend I am going to pull it out again and looking for any advice on what I should look at/check for, etc. Need to get this back on the road asap!
Old Aug 7, 2014 | 08:38 AM
dangerous1965's Avatar
Check the pressure relief valve by the oil filter google it!
Old Aug 7, 2014 | 08:52 AM
harleygreg's Avatar
Thanks, I pulled it out, cleaned the spring and valve oiled and replaced. Anything else I should look at with it?
Old Aug 7, 2014 | 09:26 PM
Put it back in nut it's usually the spring that goes bad I said nut LOL Drinking game losing or winning!!
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
