TC lockup switch not working
Old Aug 5, 2014 | 07:49 PM
gear_grinder's Avatar
Default TC lockup switch not working
Okay, I have b connector pin 11 tapped into (not cut/interrupted) and the jumper wire across the relay switched circuit. I have a good ground on the firewall for the switch to connect to, the switch is good. What strikes me as strange is that according to my multi meter using the continuity test function it shows the tapped b11 pin always grounded. The trans acts completely normal. Anyone have or heard of this issue?
Old Aug 5, 2014 | 08:08 PM
JBearSVT's Avatar
For some reason, I thought it was B13. Hm. It's been awhile. What color is it?
Old Aug 5, 2014 | 08:26 PM
Orange with a black tracer
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Aug 6, 2014 | 07:45 AM
LostSoul71's Avatar
Did you jump the relay?
Old Aug 6, 2014 | 07:49 AM
yep
Old Aug 6, 2014 | 12:05 PM
4x4manonbroke's Avatar
Solenoid is bad or clutch in TC is toast ..
Old Aug 6, 2014 | 12:58 PM
The TC and sol are probably fine seeing that it locks normally in 4th gear
Old Aug 6, 2014 | 01:46 PM
LostSoul71's Avatar
May sound silly but you are 100% on the #11 and that the switch you are using is good?
Old Aug 6, 2014 | 02:04 PM
Tested the switch yesterday, it's good. I'm installing gauges tonight and I'll double checked on the wire, but I'm sure i check continuity from wire after I pulled the insulation off and the b11 pin
Old Aug 6, 2014 | 07:57 PM
Sounds like the wiring is wrong .. odd though .. Do you have the wiring diagram ? I can E-mail it to you .. mine is a 95 .. might help
But then again .. mine is a RH not an RE
