Fan clutch delete
Old Aug 5, 2014 | 01:16 PM
Enki's Avatar
Default Fan clutch delete
I've got a 98 24 valve and just bought the flex a lite 262 electric fan setup for my truck but when going to install it I had to remove the clutch fan which was completely seized on "yes I went cw" so to get it off we had to torch it now obviously that caused the fan pulley bearing to go bad so now I want to delete the whole thing completely. I need to know if it's possible to re-route the serpentine belt without this and any ideas on new belt size would be appreciated thanks in advance
Old Aug 5, 2014 | 10:26 PM
RAW's Avatar
RAW
Never heard of that being done. I imagine an assembly can be picked up for a reasonable price from a wrecker.
Old Aug 6, 2014 | 09:19 AM
Enki's Avatar
Default Fixed!
Ok I just wanted to post my findings in case anybody else here runs into this issue or does the electric fan conversion and just wants to completely remove fun clutch hub assembly like me.
I ended up using a belt from gates 1-3/32 x 70" from car quest part #k080694 I would suggest getting one maybe 5/8" longer just to give back some more slack on the tensioner but this worked great if you cut out straight past the fan pulley and route as normal under water pump and over alternator it will keep the wp running ccw
I will post a new routing diagram for this later when I get home hope this helps
Old Aug 7, 2014 | 12:38 AM
RAW's Avatar
RAW
Please let us know!
jonahakatiny
5.9L CR Performance
Jul 30, 2015 11:48 AM
Dustin M
May 21, 2015 10:19 PM
smokee
Apr 25, 2015 02:54 AM
es772
Oct 23, 2014 08:29 AM
jheavner80
Oct 20, 2014 12:16 AM
