Cleaned EGR valve now no start
Old Aug 4, 2014 | 07:48 PM
emilio2496's Avatar
Default Cleaned EGR valve now no start
Hello. I have a 6.0 2004 F-250. so i unplugged the egr valve removed it and checked to see if there was build up. Put it back in, sprayed the sensor with sensor cleaning spray. Truck cranked a few times then just stopped. tried turning the key and all the guages went to the max and the all the icons kept cutting in and out. unhooked batteries and re hooked still nothing. tried jumping now it goes to normal start up on gauges but no crank. FICM was replaced a couple weks ago. Thanks
Old Aug 5, 2014 | 05:04 PM
bobfbigman's Avatar
you didn't ing into the intake to clean it did you? if so it may be hydro locked, normally pulling #2 glow plug and cranking will clear it up.
Old Aug 5, 2014 | 07:37 PM
emilio2496's Avatar
i sprayed sensor cleaner on the mass flow sensor the day before but that's it, wasn't having issues then. Went out and bought new batteries today does normal start up procedure but nothing when i turn the key. check engine, ABS and battery light stay on. Did a code scan got B1676 . No idea how this happens by just taking out the egr valve. Also one of the bolt heads holding the egr snapped off and the other one is spinning now
PeteBug
Jun 11, 2015 12:16 PM
RayRay4991
Feb 23, 2015 07:45 AM
makuloco2000
Dec 7, 2014 11:15 AM
behrendt1061
Dec 4, 2014 05:49 PM
6_in_a_row
Sep 30, 2014 11:31 PM
