Clunking noise right side tire area
Old Aug 2, 2014 | 11:08 AM
Cummins3rdGen's Avatar
Default Clunking noise right side tire area
Every time I am coasting I can here a constant clunking noise as the tire is spinning, and when I press the brake the noise will stop until I let off the brake then it will start again. I have had people say ball joints, which my ball joints are a little loose but nothing major. I was thinking wheel bearing, but I don't understand why the noise stops when I hit the brake, so that makes me lean towards the brake pad/caliper hanging up. Any suggestions?
Old Aug 3, 2014 | 07:39 AM
Esco1's Avatar
You have 4 wheel drive?
Old Aug 4, 2014 | 07:41 AM
dangerous1965's Avatar
Loose sloppy brake pad?
Old Aug 13, 2014 | 12:05 PM
89gtcs's Avatar
Check the torque on the brake caliper and bracket assembly and see if the pad wiggles
Old Sep 6, 2014 | 04:36 PM
FlyingDutcman's Avatar
probably not the same, but my girlfriends brothers jetta had this EXACT same issue, turns out the rotor was garbage and had rusted & warped in a few spots, hope ya figure it out!
Old Sep 9, 2014 | 08:27 AM
06carli's Avatar
Brake hardware on the caliper is no good. Check the brakes if they are bad replace them and the brake hardware. If the brakes are good just replace the hardware.
dallasca
28
May 26, 2015 12:58 AM
Boatman
Mar 20, 2015 10:00 AM
2FordStrokers
Jan 11, 2015 09:40 PM
