48re overfill ?
Old Aug 2, 2014 | 08:49 AM
jpt's Avatar
jpt
Default 48re overfill ?
I had a service done with a new solenoid and fluid put in .....my ? is the service people put in 2-4 qts too much fluid and now I have a qrease line after 2000 miles of driving above the front universal joint under the bed of the truck...Is the tranny slinging out the fluid or is there a seal where the driveshaft goes in or? there are no visible leaks under the truck?
Old Aug 2, 2014 | 09:51 AM
NadirPoint's Avatar
How do you know they put in 2-4qt too much? That's like saying "I drank about a gallon of beer last nite, but I lost track after the 4th pint."
Old Aug 2, 2014 | 10:56 AM
jpt's Avatar
jpt
It is a stock pan and it's 8-10 inches above the dipstick full mark
Old Aug 2, 2014 | 11:20 AM
dangerous1965's Avatar
Is that running in Park N or Drive? Your output seal is leaking Easy fix but may be caused by overfill! I check in Drive, hot and level ground.
Old Aug 2, 2014 | 08:04 PM
jpt's Avatar
jpt
I ck it running hot in park (where is the output seal and how hard to fix diy) truck has 227,000 and is time for ujoints 5.9cummins
Old Aug 2, 2014 | 08:30 PM
It's right at the end of the tranny when you pull the driveshaft out that's the seal!
Old Aug 3, 2014 | 08:28 AM
cerberus60's Avatar
That is the reason it is showing over full. The trans needs to be checked hot, idling, level in NEUTRAL!!!! Read the dip stick instructions.
The front pinion seal leaking is not unusual. Have to mark the nut position, pull the flange to change the seal.
Kfohne21
10
May 12, 2022 10:13 AM
jeremiah1
Jul 21, 2015 06:35 PM
Jgloveracob
Wanted To Buy (WTB) - Used
Apr 18, 2015 04:19 AM
Max713
Apr 17, 2015 05:41 PM
Jgloveracob
Mar 7, 2015 07:13 PM
