new injector nozzles now runs horrible
Old Aug 1, 2014 | 10:43 AM
bklounge's Avatar
ATTN new injector nozzles now runs horrible
Alright guys, im new to the forum but i have searched literally for months about this truck and motor to build knowledge about what i was buying. I have also searched about my issue and not too many solutions they just die towards the end. The vehicle is a 00 dodge 24 valve auto with gauges bhaf and 3" straight. i have had the truck for a month now ran great as i started getting the "must haves" before getting into the better stuff. The block fuel pump crapped on me fixed that ran great had awesome pressure @15 and the vp survived as it seemed. Then i installed DAP 150 nozzles got it all installed (yes i got them pop tested) bled the beast and when it started it is running like a misfiring turd! It seems to be #6 when i crack the lines is the culprit. I have swapped injectors to see if it follows the injector and no change. NO i did not double stack copper washers. I have lapped all seals on the injectors. Any ideas of what i should look into? I really need to get this problem fixed please i have been stumped on this for a couple weeks now
Old Aug 2, 2014 | 04:29 AM
gh0stman's Avatar
From what it sounds like your problem might be in the VP44 heading to #6. Like you said you swapped injectors around and the problem stayed on 6. Good luck hope its not your VP44.
Old Aug 5, 2014 | 09:41 AM
lukesdiesel's Avatar
Is #6 getting fuel when you crack the line?
bdbfam
Aug 31, 2015 09:06 PM
Freezzman
Jul 6, 2015 03:01 PM
gunman41mag
The Sportsmen's Lounge
Mar 16, 2015 07:43 PM
dandbmcc
Mar 14, 2015 11:05 PM
Nov 5, 2014 09:40 AM
