wet Floors
Old Jul 29, 2014 | 06:34 PM
gunslingerburkhart's Avatar
Default wet Floors
I have been having the annoying issue of wet floors and I can not find the leak. The issue is on the driver side front floor will be soaking wet after a moderate-hard rain, or snow melt and the passenger is the same after a hard rain. I have replaced a damaged door seal. I have dumped buckets of water over the front half of the cab. I can not find the leak. I looked at the firewall and it does not show any signs of leaks. Could there be a leak somewhere else?
Old Jul 29, 2014 | 09:36 PM
cummins Pride's Avatar
Front windshield leaking mabye
Old Jul 30, 2014 | 12:20 AM
LostSoul71's Avatar
Check your A pillar and the body mount for the front of the Cab, rust holes there will catch any cast off from the tires and allow it to get up into the carpet. Windshield surround and even roof lights are big leak spots as well. Bad part about the windshield is that a lot of times you cannot see the leak because the glass is hiding the rust spot or hole that is leaking.
Old Jul 30, 2014 | 12:29 AM
Only way I could tell it was my windshield is because I could see the damage to the roof interior, what I did to fix it was year off the rubber stripping and pour sealer all down the groove across the cab in too of the windshield and put the rubber striping back in
Old Jul 30, 2014 | 04:49 AM
Would rocker panels lead in to there?
Old Jul 30, 2014 | 01:13 PM
But still wet when it sits so not solution.. would there be anything at the back of the cab that would leak down?
Old Jul 30, 2014 | 01:39 PM
4x4manonbroke's Avatar
Check your door seals , and the gap between them as well ..
Old Jul 31, 2014 | 12:07 AM
LostSoul71's Avatar
If your floors or rockers are rotten enough, then there is a chance you are picking up road spray. If it was just the passenger side I would suggest the heater core, however with the Driver side being the primary issue, I would think that you have a leak. There is a chance that you have a bad seal on the rear window yes. Hell I have seen guys install the split seal for the rear window with the split at the top. Have a look.
Old Jul 31, 2014 | 05:00 AM
I took a quick look, the seals at the back of the cab, on the roof, are a little raised up, possible location?
Old Jul 31, 2014 | 10:12 AM
yeah that would do it ...
