Transmission Fluid
Old Jul 29, 2014 | 01:49 PM
motormayhem's Avatar
Default Transmission Fluid
Whenever I check my fluid it drives me nuts because it is hard to tell where the level is. If I get out of the truck and check it immediatly there are a good amount of bubbles on the dipstick which seem to clear up in about a minute, but even then there are a couple which make it hard to see where the level is. The pics below are checking it when the fluid was 170* immediatly after stopping and 3min later. Is this normal?
Attached Thumbnails Transmission Fluid-img_2219.jpg   Transmission Fluid-img_2223.jpg
Old Jul 29, 2014 | 02:56 PM
4x4manonbroke's Avatar
are you checking in N ?
if not thats the issue ..
Old Jul 29, 2014 | 03:46 PM
Yup wamed up, in neutral, engine running, and on level ground.
Old Jul 29, 2014 | 04:43 PM
JBearSVT's Avatar
Do you load it through the gears before N? Idle hot for at least a minute then with the brake on, let it load for a second in 1st, 2nd, 3rd, then N and check it. I've seen bubbles out the wazoo, but I've never seen it separate like that. My initial assumption would be that you're low.
Old Jul 29, 2014 | 05:59 PM
How much should it need between low and full levels. Added 3/8 qt to see if it read better and it seems to be less bubbles, but reads like 1/4 above full so I'm not sure it was low.
Old Jul 29, 2014 | 07:27 PM
JBearSVT's Avatar
I believe the cross hatching of the safe zone covers one quart.
Old Jul 29, 2014 | 08:37 PM
Ok that's what I was gonna guess. I guess it was full and just being a pain to read.
Old Jul 30, 2014 | 01:36 PM
yes the cross hatches are a 1 qt zone .. if it's bubbling excessivly or bubbling excessivly, I woudl reccomend a flush ( like @ jiffy lube T-Tech ) .. flushed filter, TC, and pan out .. and you will know if there is any restrictions as they have a guage on the machine and can reference the Line pressure
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PD4Life
Aug 24, 2015 08:11 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
02Stain
Feb 17, 2015 10:21 PM
smokee
Nov 7, 2014 07:40 PM
