Please help!
Old Jul 29, 2014 | 12:05 AM
Brokencummins's Avatar
Default Please help!
Ran my cummins out of fuel. I was bleeding the injectors lines and it would spit and spudded couldn't get to run long. I was priming it more and then I got a weird noise in the motor and seems like it is turning over really free. I crank it over my fan spins. It sounds like the start and hitting the flywheel all the way but I no it is cause it's turning over but not running. Any help???
Old Jul 29, 2014 | 06:46 AM
94 12valve's Avatar
so it you hear the starter spinning but not engageing into the flywheel? just a free spin?
Old Jul 29, 2014 | 10:05 AM
dezeldoc's Avatar
If i read the gibberish right, he is saying it turns over but it is like it has no compression, spins free. he knows the starter is engaging as the fan spins when he cranks it.
Old Jul 29, 2014 | 11:03 AM
94 12valve's Avatar
oh I see
When you were bleading the injectors you took the line nut off correct? not the injector hold down I hope
Old Jul 29, 2014 | 11:06 AM
xzaq103's Avatar
FormerVendor
Originally Posted by 94 12valve
oh I see
Chris
Old Jul 29, 2014 | 02:55 PM
4x4manonbroke's Avatar
Yeah, loosning the returns would be a bad deal too, I always bleed mine @ the pump, usually fires quickly ...
Old Jul 29, 2014 | 03:50 PM
Yea that was what I was trying to say it seem like it's just free spinning and it's pumping fuel but making a weird noise
Old Jul 29, 2014 | 03:55 PM
I was doing my the big lines. I didn't prime it off the ones on the bottom
Old Jul 29, 2014 | 03:57 PM
Originally Posted by xzaq103
Chris
Yes the line nut not the injector itself
Old Jul 29, 2014 | 04:40 PM
JBearSVT's Avatar
Describe this weird noise it's making.
Why did you crack any lines? I've run mine out of fuel several times, and never had to crack a line or bleed anything to get it running again, just prime the LP by hand and go.
