Exhaust set up??
Old Jul 26, 2014 | 02:35 PM
sutie's Avatar
Default Exhaust set up??
Allright, it's finally time for the stack to go, bought the truck with it and was spending money on the rest of the truck and changing the exhaust is my last step. My biggest concern is getting the smoke as far away from my trailer as possible....I don't want to turn the race car black. I have compound turbos and push a lot of fuel, so I need 5" turbo back.....but what's the best system and how should it exit the truck? Thanks for any advice.
Old Jul 27, 2014 | 11:06 PM
97cummins's Avatar
one thing is can turn down your fueling a little.
As for your exhaust, you can go with the exhaust going out the rear and use a turn down exhaust tip to push the exhaust down to the road.
or you can dump out the exhaust before the rear tires.
Old Jul 28, 2014 | 06:58 AM
sutie's Avatar
My fueling is allmost perfect in respect to my power band and RPM range. the only thing left for me to mess with is changing my DV's back out. i have Full cuts in right now, and ill be swapping for a set of 191's soon and compare the difference. i like the idea of it pointing towards the ground, are there any companies that make a kit for it, or will i be making it myself??
Old Jul 28, 2014 | 09:28 AM
dango's Avatar
MBRP | MBR-S6112TD | 5" Turbo Back, Single Turn Down, T409 - Alligator Performance
this exhaust turns down right behind the rear axle. it should force the smoke under the your trailer. comes in 4" and 5"
Old Jul 28, 2014 | 12:14 PM
sutie's Avatar
Thanks for the link, i like the way thats set up....little pricey though.
Old Jul 29, 2014 | 03:02 PM
4x4manonbroke's Avatar
Check E-bay , go with Diamond Eye .. 5 " aluminized , cheeper and the same quality, and then get your choice of tips .. there are manny to choose from as well...
I have a Diamond eye 5" on my 95 12v ... sounds awesome..
Old Jul 30, 2014 | 12:26 AM
LostSoul71's Avatar
Local big rig shops will have a lot of the parts you need for much cheaper as well.
Old Jul 30, 2014 | 01:54 PM
and they have CROME !!!
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
jkidd
For Sale
Dec 9, 2014 12:33 PM
jkidd
Diesel Auto Power
Dec 9, 2014 12:16 PM
