Clutch Popping noise
Old May 2, 2008 | 09:32 AM
Buckshotmckee's Avatar
Sma't Alec!
Default Clutch Popping noise
So I just took my oldest to school and when I release the clutch there like a popping/click/clunk noise coming from it just before it hits the top. It sounds like it coming from the clutch master cylinder. I took a look up underneath and now it's not a pronounced! I can't believe all the plastic they used!
Old May 2, 2008 | 11:58 AM
Sma't Alec!
Got it figured out! The neutral safety switch slides on the clutch rod and cause it plastic on plastic it starts sticking, common problem from what I found out. I got some dry lube, graphite and put on there, problem solved.
If anyone has or starts to have the same problem, here is the fix!
boostkid
Jun 3, 2015 11:17 AM
Boatman
Mar 20, 2015 10:00 AM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Dec 18, 2014 01:44 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
