Need opinions on truck issue!!
Old Jul 21, 2014 | 09:54 PM
flyers.nhl's Avatar
Default Need opinions on truck issue!!
Recently bought my truck and took it to a local diesel shop to get inspected, well it came back with some bad news. I thought the truck sounded great, no leaks no nothing was wrong, so I thought, guy came back telling me that the sway bar and front ball joints need replacing, rear main seal, turbo is blowing exhaust back into the engine, causing the turbo to have a problem also. Coming out to be around $7000 in parts and labor. Bought the truck for $9000. Is this all worth fixing?? Engine has 214xxx miles, interior is mint, and paint and body is perfect, lifted and 33's, air bags in the back, new cold air intake. Im inbetween thoughts. I need help! What should I do?
Old Jul 22, 2014 | 04:35 AM
gh0stman's Avatar
It all depends...are you planning on keeping the truck for a while? If you like to get something new every few years I wouldnt recommend it. But if this is something you plan on keeping I would say go for it. But if you plan on getting these items replaced I would google parts and see if you can find them cheeper. $7000 is pretty high if what needs to be replaced are what you listed. Search for your parts online and either fix what you can or get a trustworthy mechanic to do the work.
Old Jul 22, 2014 | 06:38 PM
flyers.nhl's Avatar
I had them just do the sway bar and ball joints, leave the turbo and seals alone because I can do the turbo myself, and then the seals I'm going to save up and look around and see if I can find someone to do it somewhat cheap.
What turbo's would be good to replace with?
Old Jul 23, 2014 | 04:07 AM
gh0stman's Avatar
Im not wure about the turbo. I dont plan on touching mine at the moment. I have seen many other talk about the super b turbo and how good it is. Im not touching mine because I feel if I started changing/modding anything my mileage will fall (maybe Im just gun shy but I had a 4 banger truck years ago that got about 25 mpg changed the exhaust and it dropped to about 16).
But to each his own.
How much oil do you have leaking?
Old Jul 26, 2014 | 12:12 AM
TheBear's Avatar
Sounds like this mechanic likes money. I'd get some more opinions
Notso
Ford Powerstroke 08-10 6.4L
Dec 28, 2016 06:20 AM
wannadrag
May 25, 2015 03:07 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
