Power loss
Old Jul 21, 2014 | 07:40 PM
Mattj29's Avatar
Default Power loss
Is it me or should my truck have more power? From a dead stop if I mash the pedal to the floor my truck just sits there like I'm tied to a tree. After about 2 seconds it will go but not very fast. My top speed is every bit of 75-80 and it takes me awhile to get there. Truck is completely stock I just had the trans rebuilt with no upgrades. It's like I have a 4 cylinder gas motor in my truck. What is my problem? I'm not expecting a 6 second truck by no means but my cummins is pathetic right now. Does anyone know what could be wrong?
Old Jul 21, 2014 | 08:08 PM
LostSoul71's Avatar
Are you feeling all your shifts? I had a similar issue with my old auto after a rebuild. Tranny shop had not adjusted the linkage properly. Second place I took it after the first clown insisted it was my engine had it fixed in about 15 minutes.
Old Jul 21, 2014 | 10:06 PM
4x4manonbroke's Avatar
Sounds like its trying to do a 2 or even 3rd gear take off's ..
are you smokin ?
does there seem to be anything else going on that you might think of ?
Old Jul 22, 2014 | 09:20 PM
Mattj29's Avatar
Yea I'm feeling all shifts. I don't think it's shifting out of overdrive when I go up hills or floor it. Something has to be wrong just don't know what.
Old Jul 23, 2014 | 05:46 AM
JBearSVT's Avatar
TV cable out of adjustment. If it's not kicking down out of OD when you floor it, it's too loose. This is also affecting your throttle valve, not giving you full line pressure, which is part of the reason it's slow off the line. The other part is that it's a stock 12v with a stock slushbox turning the wheels. Or something else is bad internally, but I'm giving the trans builder the benefit of the doubt at this juncture.
Old Jul 23, 2014 | 12:03 PM
Mattj29's Avatar
do you know how to adjust it?
Old Jul 23, 2014 | 01:47 PM
there is a small black box right next to the mount, you can Press ( real hard with a falt head ) and pull the cable out as far as it will adjust .. that will be full cable and no slack ... then loosen up as needed ..
Old Jul 23, 2014 | 05:30 PM
JBearSVT's Avatar
IIRC, the proper amount of slack is like, the thickness of a nickel or something like that. Don't quote me.
wiremanWelder357
May 25, 2015 09:10 PM
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
