P0148 code with power loss and smoke
Old Jul 19, 2014 | 08:57 PM
gus27's Avatar
Default P0148 code with power loss and smoke
I had my #4 fuel injection tube fail. The typical story these days but for some reason after I replaced the injection tube my motor runs fine and had good fuel pressure until the coolant reaches about 180. Then that's when all the "FUN" begins. My motor will run sluggish, blow a bunch of white smoke and throw a P0148 code (fuel delivery malfunction) which can be a number of things.
I tightened down all the injection lines so there shouldn't be any air in the system. I'm just completely stumped why if only messes up when the engine reaches a certain temperature.
I highly doubt that is a injector issue since my truck hasn't shown the signs of failing injectors.
I'm in some desperate need of some quick advice. I hope its a simple fix like re-priming the fuel lines or taking off and putting on the injector line
2006 dodge cummins 2500, quad cab short bed, 35 procomp extreme AT, 2 inch tough country level, bully dog triple dog gt, magnaflow 4 inch turbo back
Old Jul 25, 2014 | 11:14 PM
cerberus60's Avatar
The system is self priming, if the truck is running there is no issue with priming. Typical problem with these engines when the have problems warmed up is cross over tubes, injectors, PRV, or FCA. Since you already have problems with cross over tubes I would uspect all of them and maybe the install of the one that was replaced. Have to start somewhere eliminating problems.
Old Jul 25, 2014 | 11:47 PM
Bigg Redd's Avatar
When your #4 injector line failed, did your engine get a thorough soaking with fuel?
Old Jul 25, 2014 | 11:55 PM
Bigg Redd's Avatar
Actually sounds more like the FCA is failing, or has failed.
Timglow546
8
Jun 3, 2015 10:13 PM
wiremanWelder357
May 25, 2015 09:10 PM
shawnecarter
May 11, 2015 02:47 AM
RatsMC
May 4, 2015 05:25 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
