Clicking noise after dv, injectors and stud install
Old Jul 18, 2014 | 11:13 AM
wpg6.5's Avatar
Default Clicking noise after dv, injectors and stud install
So I just finished installing dv, head gasket and studs, and new injectors. Truck sat for almost. Month. Right after starting it and warming up the first time I noticed it makes a clicking noise. It only is really noticable when standing back from the truck at idle. Also seems to happen at low rpm. Once it loads up in 3rd for example it seems to go away and cannot be heard from the cab, but once I let off it seems to come back but only really noticeable if I'm driving beside a wall or something it can echo off. Sometimes it's there, and sometimes it's not, also seems to go with rpm sometimes but goes away or changes rhythm sometimes aswell. Heat doesn't seem to make a diff. Can be heard from both sides but seems more noticeable on the drivers side. And hard to pin point, when I crawl under the truck can't really hear it and when I pop the hood can't hear it at all. I'm pretty stumped. Going to take a stethoscope tonight and check the pump. Sure hope it's not the ip, was running fine before all the work.
Old Jul 18, 2014 | 02:23 PM
4x4manonbroke's Avatar
Hope you torques the studs , then the rocker pedistals then adjusted the rockers ...
In that order .... get it warm, let it sit over night ... then loosen the rockers and re-torque head, then re-run the over head adjustment ...
Old Jul 18, 2014 | 03:35 PM
wpg6.5's Avatar
I did it all to arp spec. Drove one night. Let sit over night then re torqued and all held 99% of torque only needed a ft lb or 2 on a couple and re did the valve lash. All should be well in that regard. I will likely do another torque check and valve lash check tomorrow. When it's cold. It doesn't sound like. Valve lash clicking. I've read the stock ofv can cause a ticking. Thinking maybe my big injectors and dv have dropped fuel pressure further. Ordered a Tork tek 060 valve. No stock lift pump so I know it's not that.
Old Jul 18, 2014 | 04:40 PM
yeah I did my OFV as well ... low FP was my other issue .. and I deleted my fuel heater as well ..
Old Jul 18, 2014 | 04:53 PM
wpg6.5's Avatar
I'm starting to think it's exhaust. It doesn't sound mechanical, and kind of varies. I stethoscoped the pump and valve covers and all the barrels and nothing seems to click.
Old Jul 18, 2014 | 06:28 PM
Could be a small exhaust leak starting ....
Old Jul 18, 2014 | 06:50 PM
wpg6.5's Avatar
It's incredibly hard to pin point and I have a 3rd gen manifold and turbo so it's difficult to tighten some on the bolts. Going to give it a shot from under the truck and tighten some stuff up but if that doesn't fix it I'm stumped. Only can be heard from outside the truck or slightly under it and nothing when the hood is open so can't see it being any pump or valve train parts.
Old Jul 19, 2014 | 12:18 AM
Sounds like a warped manifold or possibly a gasket issue .. start in the cente and work your way out .. you know that I'm sure !!!
Old Jul 19, 2014 | 09:42 AM
wpg6.5's Avatar
Tightened down what I could. Manifold shouldn't be warped as it's a 2 piece so should clamp pretty even. Felt around and saw no exhaust staining, loosened and re tightened the dp clamp. Nothing. I'm now completely stumped I think I'm going to turn my visit to the local diesel shop into them searching for the noise.
Old Jul 19, 2014 | 11:25 AM
How much did they mill off the head or did you do a 1 @ a time install ?
If so I'm thinking your "noise" ... could be something a bit more involved ...
