timing change, what gains will come?
Old Jul 15, 2014 | 06:52 PM
alexbland's Avatar
Default timing change, what gains will come?
alright I am wondering what gains I will get changing my timing, right now I am stock timing, and I will be going to 18 or 19* im mostly wondering about power gains.
Old Jul 15, 2014 | 08:07 PM
4x4manonbroke's Avatar
its not necessarily about power but where the power will come in @ ....
by running the timing up more your giving the engine a better chance to burn the fuel @ higher RPM's ... and to do it more efficently
Some power will be made because of the better burn though
Old Jul 15, 2014 | 08:53 PM
LostSoul71's Avatar
From what I am seeing, unless you are below factory timing, you will not see power gains until top end. If anything, you can lose at the low end. Having said that, I have not done any timing bumps yet so I can only relay what I have been reading.
Old Jul 15, 2014 | 11:52 PM
no .. it actually picked up just a bit more velocity in the bottom end ... but its not all the hype ... its better off tunin g it right .. if you have big sticks ... they deliver more fuel in less duration on the engine ... Hence you actually have a little bit of an advance there just due to the way your fuel is delivered ...
Old Jul 16, 2014 | 05:58 PM
JBearSVT's Avatar
Right. Timing is about better mpg at higher speeds and lower EGTs, not power.
Old Jul 17, 2014 | 11:13 AM
Efficency @ high rpms is nice .. i bumped mine from factory 11.5* to 15.5* ... picked up about 3 mpg @ 65 or 2K rpm's ..
Old Jul 17, 2014 | 04:47 PM
JBearSVT's Avatar
4x4, you have 4:10s? I'm somewhere between 75-80 @ 2K.
Old Jul 17, 2014 | 06:43 PM
LostSoul71's Avatar
Mine is 4.10's and I am hitting 2K at 65 to 70ish.
Old Jul 17, 2014 | 07:49 PM
JBearSVT's Avatar
Yikes.
Old Jul 17, 2014 | 07:51 PM
I'm @ 63 via GPS with 265 tires in od/lk .... @ 2k
and after the timing was bumped I went from 15 to 17.5 @ freeway speeds 65-70
