Hazing on idle, is my timing advanced or retarded
Old Jul 15, 2014 | 05:25 PM
wpg6.5's Avatar
Default Hazing on idle, is my timing advanced or retarded
Hey guys, new to the cummins side of this forum. I have a 12 valve cummin in my Chevy. Just did a bit of work to it and now it hazes a fair bit of greyish white smoke on first start of the day after sitting all night. It did it before but not as much. I always figured the truck had a fair amount of timing advance as I read somewhere that close to 20 degrees will cause this. Since I put 90 horse injectors and hybrid delivery valves. Now it hazes quite a bit, cleans up after about 5-10 of idling and after sitting all day after driving to work it doesn't haze at all. Just a small puff of black smoke. So I'm wondering if this is timing advance or timing retard I'm dealing with. Don't wanna pay someone 300$ just to find out I have around 20 degrees because I'm ok with that. Any insight would be greatly appreciated!
Old Jul 15, 2014 | 08:05 PM
4x4manonbroke's Avatar
Sounds fairly normal to me ... might toss a Tork-Tek OFV adjustable in the return side to boost the Fuel pressure .. Helped mine quite a bit ..
Larryb - ADJUSTABLE Overflow Valve for Dodge Cummins Diesel with Bosch P7100, 94-98.5
Old Jul 16, 2014 | 07:15 AM
wpg6.5's Avatar
Hmm, alrighty. To be honest it really isn't a bad haze at all. I might just be being paranoid. I just started it not even 10 min ago and haze is all gone. I should be ok fuel pressure wise as I have an air dog lift pump but I guess an adjustable banjo couldn't hurt.
Old Jul 16, 2014 | 11:27 AM
AHH.. if you would.. Fill out the Sig so we know all thats been done so we can suggest better what to do ... and yeah the air dog should be enough ... and a cold haze is normal for bumped timing and ff fuel plate ..
Old Jul 17, 2014 | 12:22 AM
97cummins's Avatar
The haze is nothing to worry about. Mine does the same thing.
I talked to a guy that works on cummins on motors, and he said that is from a little fuel leaking out of the injector and building on top of the piston. That haze is just after the motor starts and the fuel is burned up.
Old Jul 17, 2014 | 11:29 AM
Yup ... but i must admit .. after the OFV... it starts and idles better, and less haze all around ..
Old Jul 17, 2014 | 10:56 PM
wpg6.5's Avatar
Just filled out my sig, id hope my injectors aren't leaking. they are brand new. Thanks for the input guys any info/opinion helps. Id like to go for 20 degrees but I'm not sure where i stand and if he did internal or on the motor timing so i don't want to **** it up or pay a place out the *** to find out i have like 18 or something.
Old Jul 17, 2014 | 11:08 PM
Ok, If you dont have ARP studs or something comparable, your not gonna want to do much more than what your currently running or a leaking HG is real near !!
Old Jul 18, 2014 | 07:04 AM
wpg6.5's Avatar
I have arp 625 custom aged studs I just installed. So I should be good. My head gasket was already leaking so I did it, studs, head work, injectors, dv's and a new exhaust manifold and intake horn.
Old Jul 18, 2014 | 10:58 AM
damn ... yeah, your covered ...
And the 625's should be good to around what 80+ psi ... LOL....
