Truck cutting off while driving when hot then cranks back after cool down.
Old Jul 12, 2014 | 03:47 PM
mgw50's Avatar
Default Truck cutting off while driving when hot then cranks back after cool down.
I have a 2004 Ford F250 6.0L and the other day I was turning and got up to about 30mph and the truck cut off. After about 5 minutes the truck cranked back. There's no weird sounds coming from the engine. Anyone know what it might be?
Old Jul 22, 2014 | 08:35 PM
Diesellife1987's Avatar
Possibly dummy plugs. Front and rear both side.
Old Jul 23, 2014 | 02:30 PM
whattruck's Avatar
Sounds like the "no hot start HPOP issue".
The cloth screen under the oil cooler clogs, then fails, sending yrs worth of crud thru the
HPOP which then causes the IPR valve screen to fail and sending crud into IPR keeping it
from closing all the way. So low HPOP pressure when hot.
Mine didn't even throw a code when it started acting up.
You will need a scanner to read the HPOP oil pressure when cranking cold and no start hot.
How about FICM voltage. If when the FICM gets hot and the output voltage drops....
Could be allot of things, you will need to monitor the most likely culprits.
j1004ss
9
Dec 23, 2021 02:59 PM
drsparkman
Nov 4, 2015 10:32 AM
Sep 22, 2015 04:30 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
