start sounds different. no shutter on shut down .
Old Jul 12, 2014 | 10:53 AM
twisted5.9's Avatar
Default start sounds different. no shutter on shut down .
I had a loss of power. Start up took two or more turnovers more than usual. Shut down always had a hard shutter up until the loss of power.
Replaced the injectors myself with 60 horse power bocsh.
Now running a little rough and at cruiseing speed 60 mph just steady throttle pressure not excelerating or decelerating it really shutters hard and only stops if I throttle up or down.
Please help.
Old Jul 12, 2014 | 02:15 PM
Bigg Redd's Avatar
How many miles on your rig? What is your fuel pressure? Fuel Filter change? Have you pressure washed your engine lately? Any codes? Start simple first. check all electrical connections, clean your battery terminals, locate and clean all ground connections in the engine bay. There are several. Injectors, injector tubes, and lines torqued to factory spec?
Old Jul 12, 2014 | 10:02 PM
dangerous1965's Avatar
Did you replace the whole injector or just the tips? What programmer are you running?
Old Jul 13, 2014 | 07:41 PM
twisted5.9's Avatar
I replaced all of the injectors with new bosch injectors (the whole injector)
Just runing a cheep super chip no big deal.
Today I turned the chip down to the tow hall setting .
It hasn't shuttered or shakin again ..yet
Still feels like I have apower loss
Also
I pulled the oil fill cap off while the truck was running.
Seemed like a lot of blow back. It made a sound like presure release of..
Old Jul 13, 2014 | 10:48 PM
Put the oil cap on the hole if it blows off you have broken rings or worse!
Old Jul 13, 2014 | 10:58 PM
twisted5.9's Avatar
For real.
Any other test to check for broken ring
And does any one else agree
Not trying to offend dangerous that just ...... sucks
Also what would cause that
Old Jul 14, 2014 | 08:02 AM
Yeah it truly sucks! Where are you located?
Old Jul 14, 2014 | 11:47 AM
twisted5.9's Avatar
Default busted 5.9
Im located in marblefalls tx
Old Jul 14, 2014 | 07:29 PM
I wish I could help see if there is someone close that is into and capable of doing the r/r
If your mechanically inclined you can pull the motor and take it to a machine shop that does diesels It will be cheaper if you do the work. You can also find a take out motor that's good and just swap it. Cost will be about 4 or 5 k for the rebuild and a take out motor will be around 6k or less if your lucky! Any questions ask!
Old Jul 14, 2014 | 07:30 PM
Didn't you want to go to Sea World in San Diego for a week!
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
