need help
Old Jul 10, 2014 | 05:52 PM
cummins2132's Avatar
Default need help
I have a problem idk what to do first the dash warning lights wont come off when key is out off ignition along with the overhead dash that displays how much fuel u have till e has nothing but --. I cant hear the lift pump go off when I turn the key I also seem to have no power to engine because the boost fooler wont light up or anything cranks but no start. it all started from when someone was trying to wire electric fans and got the truck to run but wouldn't shut off when key was off so what he did was pull the battery cables off one at a time so plz help what could it be
Old Jul 11, 2014 | 08:56 AM
dangerous1965's Avatar
Fried PCM worst case. Dirty terminals probably. Disconnect the fans and see what happens.
Old Jul 12, 2014 | 09:47 AM
I was thinking that now bc everything is clean and good fans are disconnected Ill wire them after I figure out how to get power to the engine ig from the ecu
Old Jul 12, 2014 | 09:56 AM
Dealer can hook up and tell you whats up! Where did they hook up to power the fans?
Old Jul 12, 2014 | 10:51 AM
dealer wont do it they cant get power to the engine to pull codes the dash lights stay on and on the cp3 controller it keeps blowing fuses
Old Jul 12, 2014 | 10:09 PM
You have a short to ground somewhere possibly the controller unhook it. I assume you have dual CP3's Damn this keeps getting worse! Something melted when the fans were hooked up find out where they were hooked up for power! Back trace wires if it goes into the PCM your screwed!
Old Jul 13, 2014 | 12:04 PM
im fixing to and ya I have dual and ur telling me its a headache im ready to drive this thing off a cliff and which wires controller wires and wires to fan were hooked to overhead console then switched to radio fuse hooked to circuit breaker to positive terminal that's what a buddy told me
