What is with dodge autos and the loose stall
So I have a built Trans with a triple disk. I can't tell if it is slipping or if it is just a super high stall. Someone at a Shop told me it was 1600. It takes a while for the smoke to clear and the turbo to spool and it to grab. It's almost like the lock up is 1600-2100 and it is a DOG until overdrive finally shifts on. I can also post a video. In addition towing is horrible at low speeds. It winds up boost and Rpms, and again makes it seem like a Bad TC.
Fluid is good and only a year old. Trans is a Goerend, I bought it used, I don't know anything more about it. Valve body is new. Also truck has a #0 ground plate, 30psi, adjusted afc, exhaust, and AFE BHAF
Well, if it's a Goerend, it shouldn't be a matter of build quality. I'd get the line pressure checked. It also sounds like you need a lockup switch. Part of the reason it's a dog until OD is because the TC isn't locking until it shifts into 4th, that's just how they are. But again, if you don't have enough line pressure for whatever reason, it's going to be even worse.
God that explaines a lot. What a horrible design. So a lock up switch will it permanently lock it while its flipped? As in if I lock it at 1400 in 1st it will stay locked through all gears? Also. Part of the problem is its almost like the TPS take a sec or so to realize accelerating which is cause of the lag somewhat. Indont know if this is normal or not. That also explaines the towing problem. I'm used to towing with a gasser and a 7.3 auto. So do the nv4500 and other manual dodges "pull" and "hook up" a lot better? Or does the loss of boost between the shifts make it slower than the auto.
Have you adjusted the AFC at all ???
Any smoke ?
What adjustments have you made ??
what size tires ?
Please fill out the Singature , this will help with our "Hypothesis' " as to what to suggest ...
Any smoke ?
what size tires ?
whats a horrible design? this stye transmission was used for hell probably 35 years by chrysler. they arnt junk just need a little tuning to work well with a diesel wich has such a narrow typically hard power band.
and yes you flip the switch and it is locked into full power ttransfer through the converter/input shaft. it is HORRIBLE for the longevity of any transmission.
