Oil leaking between the powersteering and vacuum pump
Old Jul 8, 2014 | 04:48 PM
98cummins's Avatar
Default Oil leaking between the powersteering and vacuum pump
Hey guys just got done dumping about $1500 in my 99 dually after some very pesky oil leak fixes turned expensive. Long story short my bolts came out of my powersteering pump and wrecked the seal and i dumped all but two qts of oil on the side of the road. Brought the truck hoe pulled pumps and replaced powersteering with a new pump and then replaced the seal with the cummins kit. Had to replace the drive dog on the vacuum pump with a new one from gould's electric and machine and put it all back together. Mr. Gould told me i should put his double lip seal in as i would be doing the seal again in about 600 miles thanks to cummins poor seal. He was partially right, i got 6 hours out of it before it started leaking again. Does cummins offer a better seal or is the Gouuld seal the only way to go or is there enough room in that housing a guy could put a second seal? I want this to be the last time i pull this damn pump assembly. Input?
Old Jul 10, 2014 | 08:41 PM
tiremann9669's Avatar
Get the Gould
