boost fooler good or bad??
Old Jul 7, 2014 | 09:58 AM
aoutlaw95's Avatar
Default boost fooler good or bad??
I'm thinking about buying a boost fooler for my 2nd gen 24 valve Cummins is this a good or bad idea? Don't want to sound ignorant but I've got a list of things I'm wanting to do to the truck and slowly building it up but I don't want to tear anything up y'all help me out!
Old Jul 7, 2014 | 03:52 PM
turbo2332's Avatar
do it. its a great beginner mod. run the turbo about 35-40 psi WOT.
Old Jul 10, 2014 | 03:28 PM
Bigg Redd's Avatar
X2 on the boost fooler. THat was my third mod. I went first with exhaust, then Intake & CAI, and then boost fooler. It cuts down on exhaust smoke and helps efficiency.
Old Sep 2, 2014 | 11:25 PM
aoutlaw95's Avatar
How do I change the turbo pressure? And what did you do to the exhaust?
Old Sep 3, 2014 | 02:38 PM
Bigg Redd's Avatar
The Boost Fooler will add boost pressure. It literally fools the computer "telling" it that there isnt enough boost. On a stock engine the boost fooler will add 8-10 psi additional boost. More fuel, more boost. FYI, most programmers have a boost fooler built in. Chech that out first before you get a stand alone boost fooler.
As for my exhaust, I replaced the exhaust system with an AEM 4 inch mandrel bent system from the turbo all the way back. I later found a 5 inch tail section on ebay and bought it. I had it welded to the muffler, and now it looks like a 5" exhaust system from the rear.
Old Sep 4, 2014 | 06:01 AM
aoutlaw95's Avatar
Oh OK and that sounds pretty bad which programmer would you recommend for a dodge anyways I've heard the smarty is the best way to go for a dodge? And thanks for the help yall!
Old Sep 4, 2014 | 09:54 AM
Bigg Redd's Avatar
Ya cant beat the Smarty & Smarty Jr. Ive used the Smarty Jr. in the past. I still have it but currently not using it. I may re install it after my trans rebuild. Its on borrowed time as it is.
Old Sep 4, 2014 | 10:22 PM
yjay's Avatar
I would agree on a common rail. Otherwise I'd say Edge. More power. On the fly adjustability. Smarty does make great products though there's no doubt. I haven't ever run one. 65 hp added on a stock VP truck. Edge will make 120, 150 with hot unlock. Plus with the Juice with Attitude you get data logging, backdown settings, gauges, turbo timer, etc.
Old Sep 5, 2014 | 05:10 AM
aoutlaw95's Avatar
Thanks guys I sure do appreciate all the help!
Old Sep 5, 2014 | 05:33 AM
gh0stman's Avatar
Edge is the way to go. Not only for the power, but the features.
