Oil leak between turbo and manifold?
Old Jul 6, 2014 | 11:28 PM
Irzyk's Avatar
Default Oil leak between turbo and manifold?
I'm getting some oil leaking out from my manifold. I tried to search it on the threads bud seems like it's more common to happen between the head and the manifold were as mines leaking right were the turbo bolts on.. what do you guys think?
Old Jul 7, 2014 | 12:36 AM
4x4manonbroke's Avatar
Most likley its comming out of the valve guides , and its seeping into the cracks in the manifold gaskets ..
Old Jul 7, 2014 | 12:39 AM
Irzyk's Avatar
do you think it could possibly be a bad seal in the turbo? :/
Old Jul 7, 2014 | 12:14 PM
No ususally the oil would go into one of 2 places .. down pipe or CAC ... not back to manifold ... whith the engine running there would be too much pressure and the oil would not be able to settle in manifold area..
Note: how ever it is worth checking turbo, in/out play and up/down play .... and if there is infact a presence of oil anywhere in turbo ...
Keep us posted
Old Jul 7, 2014 | 08:21 PM
Irzyk's Avatar
Ok thank you, I'll check for turbo play and oil in a bit and if it checks out good ill start looking as to we're a good cummins shop is to get the seals done, and does having those deals leak Hurt the engine or is it ok to drive?
Old Jul 7, 2014 | 10:25 PM
Go to Source Automotive .. Clackamas Or .. HIGHLY RECCOMEND THEM !!!!!!!!
Old Jul 7, 2014 | 10:26 PM
Diesel & Dodge Performance Parts, Cummins Performance, Diesel Injectors
These guys are straight up, they only will do what needs to be done and they are real fair and will give you all the info they have to give ...
Old Jul 7, 2014 | 11:04 PM
Irzyk's Avatar
Alright thanks man I appreciate it. Do you
Think it is ok to run until I can get it fixed or should I stop driving it?
Old Jul 8, 2014 | 03:55 PM
I would limit your driving until your turbo get inspected .... it could pop and that would be real bad !!!!
Old Jul 8, 2014 | 11:24 PM
detroitdiesel idi's Avatar
X2
